I am trying to get the redirect for the outlook iapp to work a little better. Here is the redirect:
if { ([HTTP::uri] == “/”) } {
HTTP::redirect https://[HTTP::host]/owa/
I need it to do this but ignore the rest of the uri. so if a user enters lets say = https://webmail.company.com/owa/cookie_example, i want it to redirect to https://webmail.company.com/owa/ (not including the cookie_example).
so basically i want it to look for “/” or “owa” and redirect it to only https://webmail.company.com/owa/. ignoring all other bits of uri.
is the logic (redirect / or /owa/something to /owa/) indeed correct? i think it may cause an issue in accessing application. anyway, this is an example.
configuration
[root@ve11a:Active:In Sync] config tmsh list ltm rule qux
ltm rule qux {
switch -glob [string tolower [HTTP::path]] {
"/owa/" {
Do nothing
"/owa/*" {
HTTP::redirect "https://[HTTP::host]/owa/"
default {
Do nothing
test
[root@ve11a:Active:In Sync] config curl -I http://172.28.24.10/
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
[root@ve11a:Active:In Sync] config curl -I http://172.28.24.10/owa/something
HTTP/1.0 302 Found
Server: BigIP
Content-Length: 0
HTTP/1.1 404 Not Found
Date: Tue, 02 Jun 2015 04:12:26 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Sun, 09 Feb 2014 08:39:51 GMT
ETag: "41879c-59-2a9c23c0"
Accept-Ranges: bytes
Content-Length: 89
Content-Type: text/html; charset=UTF-8
Yah, this code breaks the ability to create a new email etc… I am just getting my users to clear their bookmarks etc… to hopefully fix the issue. But thank you for the help
Here is some code that the F5 engineer gave me to test. Still don’t have time to test it but i thought the other people out there can have a look just in case they need it to: when RULE_INIT { set ::debug 0 } when CLIENT_ACCEPTED { if {[ info exists “first_loop”]}{ set first_loop 1 } else { set first_loop 0 } } when HTTP_REQUEST { if { $::debug } {log local0. “URI: [HTTP::uri] first_loop: $first_loop” } if { [HTTP::uri] == “/” } { if { $::debug } {log local0. “URI: [HTTP::uri] path_slash”} HTTP::redirect https://[HTTP::host]/owa/ } if { $first_loop == 0 } { if { $::debug } {log local0. “URI: [HTTP::uri] first_if: $first_loop” } set first_loop 1 if { [HTTP::uri] starts_with “/owa/” } { HTTP::uri /owa/ } } }
