Need help with parsing URI
Greetings!
I have a bunch of URI’s in our application like the following
http://foo.bar.com/wiki/a/b/e.html
http://foo.bar.com/wiki/p/q/r/s/t.html
http://foo.bar.com/wiki/x/y/z.html
I would like to do a redirect using iRules to eliminate the first directory “/wiki”
so if a request comes to http://foo.bar.com/wiki/a/b/e.html it should 301 to http://foo.bar.com/a/b/e.html and so on…
Can some one please help me?
Thanks,
Anish
Hi Anish,
You can trim off the /wiki using string range:
    Check if URI starts with /wiki/
   if {[HTTP::uri] starts_with "/wiki/"}{
       Send a local redirect without the /wiki string
      HTTP::respond 301 Location [string range [HTTP::uri] 5 end]
Aaron
Thanks Aaron
That worked splendidly
Regards
Anish
