Hi All,
Can anyone one help with this simple redirection:
When users http://adeniyiqa.ngasystem.com/CMWM should be redirected to http://adeniyiqa.ngadsystem.com:8003/CMWM
Thanks for you help in advance.
Ade
Hi All,
Ade
If you want redirection specific to above host and uri, you can use below iRule. But if you need same redirection for all host with same URI and/or same host with different uri, you need to modify iRule statements accordingly. Let me know if below iRule works for you.
if { [HTTP::host] contains "adeniyiqa.ngasystem.com" }{
if { [HTTP::uri] starts_with "/cmwm" }{
HTTP::redirect <a href="http://adeniyiqa.ngasystem.com:8003/cmwm" target="_blank" rel="nofollow noopener noreferrer">http://adeniyiqa.ngasystem.com:8003/cmwm</a>
Mayur
Hi Mayur,
Thanks for a quick response.
Now I cannot attached it to the VS. It generate error below:
"01071912:3: HTTP_REQUEST event in rule (/Common/adeniyiqa
) requires an associated HTTP or FASTHTTP profile on the virtual-server (/Common/adeniyiqa.ngasystem
.vs.tcp.8003)."
If I associate HTTP OR FASHTTP profile to the VS it stop working completely because the backend is not build on http.
Is it possible for you to share Virtual Server & backend pool member configuration here to verify same?
Mayur
