Need help with Irule to redirect based on http path or host header
I need to create an irule that will redirect traffic to a different pool bassed on the following criteria. The http path begins with /socket.io OR ((The http header ‘Upgrade’ contains the string ‘WebSocket’) AND (the http header ‘Host’ begins with ‘ws’)). This is what I have so far, any help is appreciated.
Assign a pool HTTP path
    switch -glob [string tolower [HTTP::path]] {
        "/socket.io*" {
         select the pool
            pool poolA
elseif HTTP::request {
    switch -glob [string tolower [http_host]] contains { "
Try this, just a quick iRule thrown together
    if { [string tolower [HTTP::path]] starts_with "/socket.io" } {
       pool poolA
       } elseif { { [HTTP::header "Upgrade"] contains "Upgrade" } && { [string tolower [HTTP::host]] starts_with "ws" } } {
       pool poolb
Just be careful, the first condition for your elseif will be :
elseif { { [HTTP::header "Upgrade"] contains "WebSocket" } && { [string tolower [HTTP::host]] starts_with "ws" } } {
The mistake was just on “Upgrade” instead of “WebSocket”
Good catch typed to fast. Thanks
So next question if none of those conditions match will the default pool be chosen or do I have to put else default at the end of the rule?
Yes you’re right, if none of this conditions match your default pool will be chosen.
Here is the irule I have, let me know if it looks correct.
Assign a pool HTTP path matches
 if {
    pool pl_vantage-beta_1337
Or if header string matches
} elseif { { [HTTP::header "Upgrade"] contains "WebSocket" } && { [string tolower  [HTTP::host]] starts_with "ws" }} {
    pool pl_vantage-beta_1337 }
Otherwise use default pool
    default {
        pool pl_vantage-beta_http
Your last condition is not good. Default is only used when you use the “switch” parser instead of multiples if, elseif…
So you can replace default by else and it will work.
Remember that you don’t need to use your last line with the else, because on your virtual server you can set a default pool.
Awesome, thanks for the help guys I am going to test this out today.
Here is the final irlule, when I add it to the virtual everything breaks. If you guys could take a look I would appreciate it. Thanks
Everything breaks ?!
Could you tell us what you’re’re doing as tests ?
Just going to the page via internet explorer. When I go to the main page with no uri I get nothing back. So none of the conditions should match and I should be sent to the default pool. Works fine before I put the irule in.
Is it a SSL traffic ? If yes are you doing SSL termination on your BIG-IP ?
Otherwise, could you add a pool assign condition to your last line in order to check if it matches your iRule.
It is SSL traffic and it is being terminated on the LTM. I’m not following you on the pool assign condition.
Sorry, I made a mistake using the word condition.
What I suggested to you is to add this at the end of your iRule
pool your_poolname
do I need an else before that statement?
You can add an else but it’s not mandatory because it’s your last order in your iRule.
New irule still doesn’t work, same as before. Going to try support. Thanks
 if { [string tolower [HTTP::path]] starts_with "/socket.io*" } {
