Hello All,
I have two vips configured 148.x.x.228:443 and 148.x.x.228:80.
with 148.177.29.248:80 Irule “when HTTP_REQUEST { HTTP::redirect https://[HTTP::host][HTTP::uri] }” associated to redirect all http request to 148.x.x.228:443
Now i want to create new i rule which i need to associate with pool under VIP 148.x.x.228:443
1-
2-
3-https://order360.jnjgateway.com/eIFU/CustomError.html
if first URL is not working then it must redirect to third URL. if second URLis not workinh then its must redirect to third URL.
can we achieve this with single iRULE.?
Regards Manoj
Try this irule. Hope it will work as per requirement.
if { [active_members [LB::server pool]] == 0 } {
HTTP::redirect "https://order360.jnjgateway.com/eIFU/CustomError.html" }
else { HTTP::redirect "https://[HTTP::host][HTTP::uri]" }
do i need to define the name of pool in place of “server pool”.
when HTTP_REQUEST { if { [active_members [LB::Site-148.x.x.x_4001]] == 0 } { HTTP::redirect "; } else { HTTP::redirect “https://[HTTP::host][HTTP::uri]” } }
No need to define pool name, it will take default pool which is tagged to VIP. If you want then use below option.
if { [active_members POOL-NAME] == 0 }
