Need Help on merging the 2 Irule
i want to merge the below 2 irule into one irule.
can any one help me on this.
rule abc_prod_api '{
when CLIENT_ACCEPTED { if { [[ IP::client_addr] equals 63.95.36.13] } { pool prod_res_comm_ssl_196 } elseif { [[ IP::client_addr] equals 216.195.77.144] } { pool prod_res_comm_ssl_199 } } }’
rule abc_prod_api {
switch -glob [string tolower [HTTP::uri]] {
“/mers/api*” {
persist none
pool prod_res_comm_ssl_api
default {
persist source_addr
Hi prasanna,
You are going to need to get them all into the same event so that you can escape some of the routing that is being performed with return statements.
If you simply merge them the default actions inside of the second iRules switch statement would override the IP Address matching in the first iRules CLIENT_ACCEPTED Event.
if { [IP::addr [IP::client_addr] equals 63.95.36.13 ] } {
return
if { [IP::addr [IP::client_addr] equals 216.195.77.144 ] } {
return
"/mers/api*" {
persist none
default {
persist source_addr
Hope this helps.
