Need help on CreateParition error....
Hi
Follwoing code throwing Null Pointer Exception when I try to run it
// Create partition
void createPartition() throws Exception
iControl.ManagementPartitionAuthZPartition partition = new
iControl.ManagementPartitionAuthZPartition();
partition.setDescription(“Customer 1 Partition”);
partition.setPartition_name(“Customer1”);
iControl.ManagementPartitionAuthZPartition[] partitions = {partition};
m_partition.create_partition(partitions);
System.out.println(" Partition created sucessfully ");
I don’t see anything wrong with the code. Is the Null Pointer Exception on the client side before the SOAP request is made or it an iControl exception returned from the server in a SOAP Fault?
A couple of questions that might have been overlooked.
1. Is m_partition null?
2. Is partitions initialized as an array with 1 dimension?
3. Is partitions[0] null?
The only one I’m not sure about is 1 as I don’t see where you initialize that variable. I’d step through in a debugger and find out which line is causing the exception and then which variable is null at the point of the exception.
-Joe
Thanks for pointing out. It was my mistack I didn’t initilized the
m_partition = (iControl.ManagementPartitionBindingStub)
new iControl.ManagementPartitionLocator().getManagementPartitionPort(new java.net.URL(m_endpoint));
it works now.
Great! It’s funny how often it turns out the source of issues are not really what it seems…
-Joe
