Need help of redirects
So i have hit a stand still on this issue. When i hit the VS on my browser with the uri it directly takes me to the server hostname instead of the F5.
For ex: i hit takes me to the default page and is also displayed the same on the browser. When i hit it takes me to the server landing page nodename1.com/login instead of the F5. I think there is a redirect on the server for the URI. Can this be altered using the Irule ?
Trying to understand your issue here.
QQ: what do you mean by instead of F5? If you hit VS url in the browser and getting a page hosted on server, this means your request is proxying through F5 to the server.
Is this not your expected result? If not, Help me understand!
hi PK,
I think i was not able to potray the information properly. What you are saying is fine. What i mean is when i put abc.com/login it should take me to abc.com/xxx something right , on my browser page i see the direct url of the node behind the f5 like nodename1.com/xxxx etc.
Can you post output of below command. (Mask confidential fields if any)
tmsh list ltm virtual VS_NAME all-properties
