I would appreciate if some one could help me in create iRule/datagroup and applying iRule to allow only few URI’s and remaining all should go to invalid page.
https://Ind-hyd.vidya.com/KURservlet/servlet/KURServlet https://Ind-hyd.vidya.com/KURservlet-stage/servlet/KURServlet https://Ind-hyd.vidya.com/KURservlet-test/servlet/KURServlet
All other request should be sent to the below error page: https://Ind-hyd.vidya.com/error/invalid.html
The previous irule must generate cyclic redirect as the else statement redirect to the same URL.
the following irule must answer the need:
switch -glob [string tolower [HTTP::path]] {
switch -glob [HTTP::path] {
"/KURservlet/servlet/KURServlet*" -
"/KURservlet-stage/servlet/KURServlet*" -
"/KURservlet-test/servlet/KURServlet*" {}
default { HTTP::redirect noserver "https://Ind-hyd.vidya.com/error/invalid.html }
The commented line is if you need to ignore the case. if you use this line, all conditions must be changed to lowercase.
