Need help in creating a monitor
Hello All,
I got a requirement to create a monitor to check the health of a host.
Type the REST API command GET https://IP_Address:443/xxx.yyy
the response would be -
HTTP/1.1 200 OK
Please let me know what would be the format of send and receive string.
have you already tried yourself? there is lots of information on this available if you search, i would advise you to look at that and then try or show what you think it should be
start here and follow the links:
https://devcentral.f5.com/s/question/0D51T00006kH8mK/send-and-receive-string-explanation-in-a-http-monitor
