When I create a basic HTTP monitor and use a hostname the result is that the actual ip address of the host is used in the monitor. A one time nslookup is done.
If the ip address of the host changes, the health monitor will fail.
Is there a way to use the hostename only all the time, by doing an nslookup every time?
I expect it can be done by an external script, but I was not able to find an example on DevCentral.
Does the web server have virtual host or host header definitions that require a specific hostname be inserted in all requests? I wasn’t aware that any name resolution would be done for a monitor send string. I would have guessed that the static string would be sent in the monitor request. Can you clarify what you’ve tested and which version you’ve tested on?
I use this a health monitor to check the status of the ISP link on a Link Controller. I want to check that some internet web pages are reachable by just doing a “GET /”.
If I configure the basic http monitor I type for instance www.nu.nl as the adress to be checked. If the monitor is now created I see that the ip address is put in there instead of www.nu.nl.
monitor HTTP-Nu {
defaults from http
transparent
dest 62.69.179.231:http
Now if www.nu.nl changes the ip address, the monitor will still check the old address and therefore fails.
So I need a script that can do an dns lookup first and then do the check on the resolved ip address.
BIGIP is running version: 9.4.5 with HF2 (soon to be upgraded to 10.0.1
I think you might need to use an external monitor. It would be a fairly simple one to implement using curl as long as you have DNS resolution configured. curl accepts a hostname and will perform name resolution before sending the request.
The Monitoring Codeshare has several examples of external curl-based HTTP monitors.
