Need help convert 4.x irule to 9.x
I have the following I rule that I neeed help in moving to 9.x.
if (client_addr == 10.168.1.0 netmask 255.255.255.0 or
client_addr == 10.170.64.0 netmask 255.255.192.0 or
client_addr == 10.42.0.0 netmask 255.255.192.0
or client_addr == 160.76.0.0 netmask 255.255.0.0 ) {
use pool Visionware_web28
else {
use pool Visionware_web27
If anyone could help me it would be great.
You can define the address ranges in a datagroup (called a class in the bigip.conf) under Local Traffic >> iRules >> Datagroup tab >> Create >> Name: my_networks_class, Type: address.
Then create a rule which checks the client IP address against the class, using the matchclass (Click here) command. You can the codeshare links at the bottom of the matchclass wiki page for related examples.
when CLIENT_ACCEPTED {
   if { [matchclass [IP::remote_addr] equals $::my_networks_class] } {
      log local0. "[IP::client_addr]:[TCP::client_port] matched \$::my_networks_class: $::my_networks_class"
      log local0. "[IP::client_addr]:[TCP::client_port] didn't match \$::my_networks_class: $::my_networks_class"
The log output is written to /var/log/ltm. To save resources, comment out or remove the log statements from the iRule once you’re done testing.
Aaron
