Need assistance creating an iRule to modify a URI
If the following path is detected the F5 should change the URI to append /EXAMPLE to the beginning:
/TestProcess.php
Corrected URI would be: /example/TestProcess.php
Thanks.
Do you need users to see the /example/ or is that just where you want it to land on the server side?
This will change the URI and send it to server:
if { [HTTP::uri] eq "/TestProcess.php" } {
HTTP::uri /example[HTTP::uri]
This will send a redirect to the client asking them to request the resource again:
HTTP::respond 301 Location "http://[HTTP::host]example[HTTP::uri]"
This is just for a backwards compatibility issue, so I believe it’s not important for the users to see the actual redirected URI, just where they land. Hope that makes sense.
You should check out ProxyPass. It’s an iRule that will handle what you’re describing. It essentially shows one URI on the client side and another on the server side. It is well documented as well, so you shouldn’t have any trouble standing it up.
