Need a Simple iRule
HI
I am new to iRules and have a need to check the content of a cookied, if it matches then I need to send to a pool if not re-direct it to a sorry page. Below is what I have:
if { [HTTP::cookie contains “abcdefgh”] }
pool test
else { [HTTP::redirect http:\\sorry.x.y]}
I have also tried using HTTP_RESPONSE, the F5 takes the rule but in the statistics it fails each time its used.
Thanks for all your help.
add this line and watch the logs…
log local0. “check for [HTTP::cookie contains]”
Hi
To clarify:
if { [HTTP::cookie contains “abcdefgh”] log local0.}
pool test
Is this correct?
Ramesh -
You want to do:
 log local0. "check for [HTTP::cookie contains]"
 if { [HTTP::cookie contains "abcdefgh"] }
 pool test
Also, what is the name of the cookie that is being tested?
I am not sure of the name but we can give it a value, I am in the process of finding this out. So once I put this line, how do I check whats going on? Is there a command line command I can type to see the data?
Thanks for all your help, after much work I have created what I needed:
log local0. “check for [HTTP::cookie value ]”
if { [HTTP::cookie value log local0. “Found cookie”
pool test
log local0. “No cookie”
HTTP::redirect “http://sorry.x.y”
