Need a help with irule - Pool Selection
Need a help with the irule, i have a https://xyz.example.com going to 10.10.10.10 pool and https://xyz.example.com:8443 going to another pool. how can we achieve this?
Regards
You can use the following irule :
    switch [HTTP::host] {
        "xyz.example.com:8443" {
            pool x
        "xyz.example.com" {
            pool y
        default {
            reject
            pool x
        "xyz.example.com" {
            pool y
        default {
            reject
it worked for me but did not fulfull my requirement :frowning:
What are your requirements ?
Why do you need an irule.
create two virtual servers:
  • one on port 443 with default pool x
  • the other on port 8443 with default pool y
