Need you support to achieve the below change.. When user is trying to access http://abc.com should be redirected to http://www.abc.com
Try this:
if { [string tolower [HTTP::host]] eq "abc.com" } {
HTTP::redirect "www.abc.com"
Hope this helps,
N
