Need a help migrating iRule from v9.4.8 to v 10.2.0
Hi All I need a help to migrate iRule from v9.4.8 to 10.2.0. Current iRule is:
when RULE_INIT {
array set ::ARRAY_100 { }
each time Data Group List is updated with new products
this irule must be updated to load the new array
so change this timestamp below to update array in memory…
TIMESTAMP: 25/09/2008:10:00am
foreach item $::hurl_list_100 {
set index [findstr $item “” 0 “:”]
set data [findstr $item “:” 1 “\n”]
set LIST “$index $data”
log $LIST
set ::ARRAY_100($index) $data
log "request "
set pool $::ARRAY_100([TCP::local_port])
log “Pool selected from array: $pool” use pool $pool
And is not initiated after upgrade to v10.2.0. I’m not very good it using array so I tried to change it to but still have a problems
when RULE_INIT {
array set ARRAY_100 { }
TIMESTAMP: 02/09/2010:10:00am
foreach item hurl_list_100 {
log $LIST set ARRAY_100($index) $data
log "request "
set pool ARRAY_100([TCP::local_port])
Any help is much appreciated
Hi Ignat,
It looks like you have an extra closing curly brace at line 21. Remove that and the rule should load fine. Don’t forget to migrate the ‘hurl_list_100’ data group as well.
Best regards,
George
Thanks George
“hurl_list_100” data group is:
class hurl_list_100 {
“33001:EVOPBBR_100-POOL”
“33002:EVOPUXR_100-POOL”
so I don’t see what has to be change in it for v10.2.0
Ignat
Hi Guys,
I decide to rewrite the iRule using class functionality with Array and it look like a better way to do it. Th eiRule and the data group class are bellow:
class hurl_list {
“1000” { “chris-pool2” }
“2000” { “chris-pool2” }
“4000” { “chris-pool1” }
“5000” { “chris-pool2” }
rule hurl-test {
when RULE_INIT {
TIMESTAMP: 09/09/2010 09:00
if {[array exists ARRAY_100]}{
array unset ARRAY_100
for {set list 0} {$list < [class size hurl_list]} {incr list} {
log local0. “[class element -name $list hurl_list] → [class element -value $list hurl_list]”
set index [class element -name $list hurl_list]
log local0.debug “Index = $index”
set data [class element -value $list hurl_list]
log local0.debug “Data = $data”
log local0.debug “\[array get ARRAY_100\]: [array get ARRAY_100]”
log "request "
pool $pool
The output of the login:
Sep 9 09:56:58 local/tmm info tmm[5257]: Rule hurl-test2 : 2000 → chris-pool2
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : Index = 2000
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : Data = chris-pool2
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : [array get ARRAY_100]: 2000 chris-pool2
Sep 9 09:56:58 local/tmm info tmm[5257]: Rule hurl-test2 : 1000 → chris-pool2
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : Index = 1000
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : [array get ARRAY_100]: 1000 chris-pool2 2000 chris-pool2
Sep 9 09:56:58 local/tmm info tmm[5257]: Rule hurl-test2 : 4000 → chris-pool1
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : Index = 4000
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : Data = chris-pool1
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : [array get ARRAY_100]: 4000 chris-pool1 1000 chris-pool2 2000 chris-pool2
Sep 9 09:56:58 local/tmm info tmm[5257]: Rule hurl-test2 : 5000 → chris-pool2
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : Index = 5000
Sep 9 09:56:58 local/tmm debug tmm[5257]: Rule hurl-test2 : [array get ARRAY_100]: 4000 chris-pool1 5000 chris-pool2 1000 chris-pool2 2000 chris-pool2
Sep 9 10:01:55 local/tmm info tmm[5257]: 01220002:6: Rule hurl-test2 : request
Sep 9 10:01:55 local/tmm info tmm[5257]: 01220002:6: Rule hurl-test2 : Pool selected from array: chris-pool2
Sep 9 10:02:18 local/tmm info tmm[5257]: 01220002:6: Rule hurl-test2 : request
Sep 9 10:02:18 local/tmm info tmm[5257]: 01220002:6: Rule hurl-test2 : Pool selected from array: chris-pool1
Thanks for your reply
Ignat
