NEDS Rule
Problem this snippet solves:
Used in conjunction with the NEDS specification contained in the Logging & Reporting Toolkit series.
Code :
when RULE_INIT {
    set ::inbound_vlan "4094"
    set ::device_id "mybigip.test.net"
    set ::strlimit 256
    set ::doAES 0
    set ::AESKey "F(NY$*@&TYY%($&@(%SLJSDLF"
when CLIENT_ACCEPTED {
    set secs [clock seconds]
    set usecs [expr {[clock clicks] - [expr {$secs * 1000000}]}]
    # Since the seconds counter can increment between the two clock
    # calls above, we need to correct for values over 1000000.
    # This may adjust the measured time to be somewhere between
    # the two calls (instead of using the second measurement).
    # All other rollover conditions will not cause a problem.
    if { $usecs > 1000000 } {
        set usecs "999999"
        set usecs [format "%06u" $usecs]
    set conn_start_time $secs.$usecs
    set clientside_client_addr [IP::client_addr]
    set clientside_client_port [TCP::client_port]
    set clientside_server_addr [IP::local_addr]
    set clientside_server_port [TCP::local_port]
    set clientflow "$clientside_client_addr:$clientside_client_port"
    append clientflow "-$clientside_server_addr:$clientside_server_port@$conn_start_time"
    set vlanid "[LINK::vlan_id]"
    if { [string compare $vlanid $::inbound_vlan] } {
        set direction "Inbound"
        set direction "Outbound"
    set log_event "neds.f5.conn.start.v1"
    set log_content "\"$::device_id\","
    append log_content "\"$clientflow\","
    append log_content "$conn_start_time,"
    append log_content "\"[LINK::vlan_id]\","
    append log_content "[IP::protocol],"
    append log_content "[IP::tos],"
    append log_content "[IP::ttl],"
    append log_content "\"[virtual]\","
    append log_content "\"$direction\""
    if { $::doAES } {
        append log_event ".AES+base64"
        set log_content [b64encode [AES::encrypt $::AESKey $log_content]]
    log local0. \"$log_event\",$log_content
when CLIENT_CLOSED {
        set usecs "999999"
    set conn_end_time $secs.$usecs
    set log_event "neds.f5.conn.end.v1"
    append log_content "\"$clientflow\",$conn_end_time,"
    append log_content "[lindex [IP::stats pkts] 0],"
    append log_content "[lindex [IP::stats pkts] 1],"
    append log_content "[lindex [IP::stats bytes] 0],"
    append log_content "[lindex [IP::stats bytes] 1]"
    if { $::doAES } {
        set usecs "999999"
    set http_request_time $secs.$usecs
    set http_host [string range [HTTP::host] 0 $::strlimit]
    set http_host [string map {{"} {""}} $http_host]
    set http_request_uri [string range [HTTP::uri] 0 $::strlimit]
    set http_request_uri [string map {{"} {""}} $http_request_uri]
    set http_username [string range [HTTP::username] 0 $::strlimit]
    set http_username [string map {{"} {""}} $http_username]
    set http_user_agent [string range [HTTP::header User-Agent] 0 $::strlimit]
    set http_user_agent [string map {{"} {""}} $http_user_agent]
    set log_event "neds.f5.http.req.v1"
    append log_content "$http_request_time,"
    append log_content "[HTTP::request_num],"
    append log_content "\"$http_host\","
    append log_content "\"$http_request_uri\","
    append log_content "\"$http_username\","
    append log_content "\"$http_user_agent\""
    if { $::doAES } {
when HTTP_RESPONSE {
        set usecs "999999"
    set http_reply_time $secs.$usecs
    set content_length ""
    if { [HTTP::header exists "Content-Length"] } {
        set content_length [HTTP::header "Content-Length"]
    set lb_server "[LB::server addr]:[LB::server port]"
    if { [string compare "$lb_server" ""] == 0 } {
        set lb_server "<forwarded>"
    set status_code [HTTP::status]
    set status_code [string map {{"} {""}} $status_code]
    set content_type [HTTP::header "Content-type"]
    set content_type [string map {{"} {""}} $content_type]
    set serverside_client_addr [IP::local_addr]
    set serverside_client_port [TCP::local_port]
    set serverside_server_addr [IP::remote_addr]
    set serverside_server_port [TCP::remote_port]
    set serverflow "$serverside_client_addr:$serverside_client_port"
    append serverflow "-$serverside_server_addr:$serverside_server_port"
    set log_event "neds.f5.http.resp.v1"
    append log_content "$http_reply_time,"
    append log_content "\"$status_code\","
    append log_content "\"$content_type\","
    append log_content "\"$content_length\","
    append log_content "\"$lb_server\","
    append log_content "\"$serverflow\""
    if { $::doAES } {
}</forwarded>
