Neat and tidy iControl data extraction
Hi, I am looking for an iControl script that will list the Virtual Server name, destination IP, Pool names and Pool Member IPs in a tidy output. Surely one must exist?
I don’t mind how I call it - Python / Powershell / Perl etc but I can’t seem to find one on the site that lists the Virtual IP address with all the relevant hierarchical information.
Can anyone suggest which one to use? I would like to basically see what is on the Local Traffic Network May but include the UP.
TIA
I can whip you up a perl script in no time. Do you need status as well or just for configuration? If you could provide an example output you would like it to look like I can try to get you something close…
Actually, forgot I already wrote one. Give this a shot: DevCentral - An F5 Technical Community
I’ll produce output like this:
***** SITE MAP FOR BIG-IP  ******
/Common/myvip (VS)
|    Unknown (Enabled) The children pool member(s) either don't have service checking enabled, or service check results are not available yet
+-> /Common/mypool (P)
    +-> 10.10.10.10:80 (PM)
        | Unknown (Enabled) Pool member does not have service checking enabled
    +-> 10.10.10.20:80 (PM)
Hope this helps!
BTW, I found it on the iControl CodeShare index page at DevCentral - An F5 Technical Community where there are lots of samples for you to start with.
-Joe
Just updated the code in the codeshare sample to include the destination address. Just needed to call LocalLB.get_destination() and add that to the output. I added the destination to the end of the vip name line. There is a get_destination_v2() which includes the folder path as well but this is cleaner. Output looks like this:
$ ./LocalTrafficMap.pl bigip_addr user pass
/Common/myvip (VS) 20.20.20.20:80
+-> /Common/myirule (R)
It’s very easy to change the format of the output.
