NAME::response does not contain any A record responses
Could you please suggest how to solve this?
Issue
In the NAME_RESOLVED event I am not getting the response IP address (see below for the snippet I copy pasted from local traffic log file).
Background
I wrote a simple iRule that does address record lookup. I am following the sample here http://devcentral.f5.com/wiki/default.aspx/iRules/DestinationSnatUsingDNS.html
I verified the following:
1)/config/tmm_base.tcl has this section.
proxy RESOLV {
use server $IP_ADDR_LOCALHOST $service(domain)
serverside UDP
2) I also, had turned on recursive queries on in named.conf as mentioned in the link.
3) I also restarted by running the command – “bigstart restart tmm”
4) I added my dns server by running the command “bigpipe dns nameservers n.n.n.n”
5) I logged on to BigIP/F5 shell and verified the “dig n.n.n.n.testdomain.net +short” returns expected A response.
Here is my iRule
when CLIENT_ACCEPTED {
log local0. “Remote address is [IP::remote_addr]”
log local0. “dig for [IP::client_addr].testdomain.net”
NAME::lookup “[IP::client_addr].testdomain.net”
when NAME_RESOLVED {
log local0. “response name [NAME::response name]”
log local0. “IP address list = >[NAME::response]<”
log local0. "index0 [lindex [split [NAME::response] " “] 0]”
log local0. "index1 [lindex [split [NAME::response] " “] 1]”
log local0. "index2 [lindex [split [NAME::response] " “] 2]”
log local0. "index3 [lindex [split [NAME::response] " “] 3]”
Copy pasted snippet from (Local0)Local traffic log file:
Fri Apr 3 10:15:43 PDT 2009 tmm tmm[1350] Rule sen_dns_test NAME_RESOLVED: index3
Fri Apr 3 10:15:43 PDT 2009 tmm tmm[1350] Rule sen_dns_test NAME_RESOLVED: index2
Fri Apr 3 10:15:43 PDT 2009 tmm tmm[1350] Rule sen_dns_test NAME_RESOLVED: index1
Fri Apr 3 10:15:43 PDT 2009 tmm tmm[1350] Rule sen_dns_test NAME_RESOLVED: index0
Fri Apr 3 10:15:43 PDT 2009 tmm tmm[1350] Rule sen_dns_test NAME_RESOLVED: IP address list =
Fri Apr 3 10:15:43 PDT 2009 tmm tmm[1350] Rule sen_dns_test NAME_RESOLVED: response name 157.55.168.101.testdomain.net
Fri Apr 3 10:15:43 PDT 2009 tmm tmm[1350] Rule sen_dns_test CLIENT_ACCEPTED: dig for 157.55.168.101.testdomain.net
Fri Apr 3 10:15:43 PDT 2009 tmm tmm[1350] Rule sen_dns_test CLIENT_ACCEPTED: Remote address is 157.55.168.101
Which LTM version are you running? If you run a tcpdump filtering for the name server IP address, do you see any packets being sent/received?
Aaron
Thanks Aaron
1) tcpdump shows F5-dns traffic when I do a dig n.n.n.n.testdomain.net +short. However, I dont see any traffic when the iRule is invoked. Could you please suggest what else I need to look at to resolve this issue.
2) This is on LTM version 9.4.4.
General Properties show these:
Version BIG-IP 9.4.4 Build 65.1 Final
CPU Count 1
Active CPUs 1
CPU Mode Uniprocessor
