Have Virtual Server and Pool Monitors that I got from here (somewhere), that worked in 11.4.0. Just upgraded to 11.5.1. The monitors now fail with:
“/Common/d87ecmtstweb1v: Not enabled (noSuchObject)” for the VSs and “CHECK_BIGIP_POOL CRITICAL - Could not interpret MemberQty from the BigIP” for the pools
Commands are “$USER1$/check_f5.pl -H $ARG1$ -C string $ARG2$”, with $ARG1$ being the F5 LTM Hostname and $ARG2$ of the form “-m server:/Common/d87ecmtstweb1v”
“$USER1$/check_bigip_pool_SP.pl -H $ARG1$ -C string -S 11 -P $ARG2$”, with $ARG1$ being the F5 LTM Hostname and $ARG2$ of the form “apps_pool”
