my LTM memory issue
Hi
last day i check my LTM 6800 it consume 3GB out of 4GB total memory, can you explain why, and how to prevent it.
i restart the LTM and now i can see on LCD memory is about 200MB to 300MB.
BR
sosa
If this is not in line with your normal trends and your traffic patterns haven’t changed, it’s possible you’re facing a memory leak. Unfortunately, we aren’t equipped here to assist with those problems, you’ll need to reach out to the product support team: https://websupport.f5.com Click here
Hi
thanks for reply, on LCD screen i also see 4d DOS Attack message,it might be possible due to DOS attack on LTM, if yes , then where i can see these DOS attack logs (var/log/ltm or some where else.
BR
sosa
Hi
it was issue of ltm memory leak , which fixed after software upgrade from 9.1.2 to 9.3.1 HF8
BR
sosa
