My BIGIP is OFFLINE
Hello
I have a problem with my BIG-IP device. I used it with the version 12.1.2 and it worked very well. Then, I downgraded to the version 12.0.0. The status is OFFLINE and I don’t know why.
The response should be in the /var/lo/ltm file. You could take the messages and share here. Regards
