Multple VPE LDAP SearchDN entries
I have an LDAP query set up in VPE. I is working using the SearchDN I inserted. However I would like to add a second Search DN into this field. Is this possible? Basically I just want to search a second OU without having to open it up to a larger AD tree. My hope would be to have some thing like this:
OU=Accounts,DC=domain,DC=domain
OU=Users,DC=domain,DC=domain
Just not sure if having multiple will work, and if this format will work or if I need to use an operator of some sort.
The searchDN must be the lowest common RDN, in your case “DC=domain, DC=domain”. It’s not possible to give two differents searchDN for the same LDAP query.
It is possible however to filter on the OU by using the SearchFilter field, with this syntax:
(|(OU=Accounts,DC=domain,DC=domain)(OU=Users,DC=domain,DC=domain))
