Currently APM does not support multi-valued SAML attributes (multiple same attribute instances within SAML assertion (Bug ID 400726, SOL 14570).
Consider authentication and access control based on group membership. Typically users can be members of multiple groups. In normal AD scenario, there is AD query after the AD auth to get a list of groups. And it is easy to provide access to applications based on the group memberships.
Now is this possible with SAML federation? Many IdPs including MS Azure AD can deliver group information within SAML authentication response assertion using multi-valued attributes. This would be ideal for federated group based authentication and access control - however there is this APM bug - only the first occurrence of the attribute is parsed to a session variable. APM sees the other values but ignores them (/var/log/apm log reveals this).
Does anybody have ideas for a workaround, or info if this bug is being addresses anytime soon?
Does anybody has new information on that? In 12.0, multi valued attributed are supported on IdP, but this won’t help regarding THi’s question. To deliver AD group information to SAML SP, memberOf variable could be used. This variable is single valued (each group is concatenated with a pipe symbol) and sent as one string to SAML SP, even on 12.0.
There is a bug id 534374 that tracks the implementation of being able to separate multiple values within a single APM session variable into properly-formatted multi-valued attribute SAML syntax. I would like to ask you to log a support case and request it to be linked to that bug. Thanks.
I wrote an iRule to parse multi valued attributes from a federated SAML token and put them into one string with each element separated by a pipe:
when ACCESS_POLICY_AGENT_EVENT {
if {[ACCESS::policy agent_id] eq "di_roleParse" } {
Get the raw SAML Assertion
set samlAssertion [ACCESS::session data get "session.saml.last.assertion"]
Parse the XML and only extract the Role claim, also trim the first 76 characters so we dont keep all the attribute junk
set roleValues [findstr $samlAssertion "http://schemas.xmlsoap.org/ws/2005/05/identity/claims/role" 76 ""]
delete all the XML attribute value openers
regsub -all "" $roleValues "" roleValues
replcae all the XML attribute value closers with space pipe space
regsub -all "" $roleValues " | " roleValues
assign to a custom variable
ACCESS::session data set session.custom.attr.role $shortRoles
Has anybody changed this iRule to do it the other way around? Search for pipes and transfer it to a multi value attribute for each entry? Would help everybody who is trying to send AD groups to SAML SP as multi value attribute. I will try that as soon as I find some time.
Yep I tried that. The parser that creates SAML tokens for F5 IdP service doesn’t allow you to put XML tag characters inside attributes. It rencodes them into their URL equivilents. So when I tried to replace the pipes with ‘GROUP’"GROUP’ etc… it printed it into the SAML token like this: ‘GROUP’<&bs;saml:AttributeValue$gt; Annoying. EDIT: Oh bloody hell, this comment box has re-encoded all my URL and XML tags. See bellow so I can use a code box. Sigh.
The parser that creates SAML tokens for F5 IdP service doesn’t allow you to put XML tag characters inside attributes. It rencodes them into their URL equivilents. So when I tried to replace the pipes with ‘GROUP’‘GROUP’ etc… it printed it into the SAML token like this:
