I have a APM policy configured for MultiDomain SSO, it works fine with the first login but if inactive Timeout occurs then once user try to login it always redirects to logout page. May I need to do some more configuration or its a known issue
You might be running into BUG 498926
There is not fix for that yet.
You can try a workaround.
Work-around is modify the href of the ‘Session Expired Message’ so that it redirects to www.site.com In the text customization for the ‘Session Expired Message’, replace [SESSION_RESTART_URL] with session variable %{session.server.network.name}
thanks
gianrico
Thanks Gianrico, you are always helpful, it solved my problem
