MSSQL Health Monitor Issue
We’re currently using the F5 to load balance across read-only shards for a specific feature within our infrastructure. I have had success getting a MSSQL monitor to work initially, but every time the backend servers are rebooted, the monitor stops functioning. If I make enough cosmetic changes to the health monitor, it eventually works again.
What’s odd is if I connect via management studio to the backend nodes and run the exact query in the monitor (with same credentials), the receive string is what is expected. If I change the pool’s monitor to a basic TCP connect, and then connect via management studio to the VS’s IP, I can execute the health monitor successfully. But if I set the actual monitor on the pool, it’s still not functional.
The monitor is doing a simple select to a function that returns a single row/column with a 0 or 1 to signify whether the service is available for use.
Any thoughts on what might be the issue here?
F5 Software: BIG-IP 11.4.0 Build 2425.0 Hotfix HF4 F5 Platform: BIG-IP 5000
Can you post the monitor config and have you tried capturing it via tcpdump to see what response it actually receives?
Amusingly enough…or more like how things always go in technology…I think I figured it out. It looks like (at least in this case), if you have the “Count” option for the monitor set to 0 (ie. permanent connection), it gets itself confused when SQL is bounced (reboot or service restart). It doesn’t seem to reopen the connection, but tries to re-use the old one despite SQL having cut all connections on the restart. Not sure why I didn’t think of this before, but I tried setting it to 1 and after ~10 instances of a restart or reboot, I’m not seeing the problem anymore. Sorry for the needless question. Though I am interested if this is by design or a bug.
@Ted Waller - I ran into this same issue on v11.4.1 HF5. Thanks for posting the response. I changed the ‘Count’ field from 0 to 1 and it made my health monitor work again.
