I’m using F5 for load balancing by GX and GY request with persistence SUBSCRIPTION-ID[0]:SUBSCRIPTION-ID-DATA[0]. When i use this custom persistence, it will cause MRF function only become one direction and if traffic coming from server it will causing looping.
I’m very new to iRule related to Diameter. I hoping anyone can help me with below iRule to make it become bidirectional.
DIAMETER::persist [new-persist-key] [bidirection]
My config :- [root@SN234YLNW1V0001:Active:In Sync] tmp tmsh list /ltm virtual SCE_MRF ltm virtual SCE_MRF { description testing destination 10.26.81.66:diameter ip-protocol tcp mask 255.255.255.255 profiles { SCE_router { } diameter_session_SCE { } stats { } tcp { } } source 0.0.0.0/0 translate-address enabled translate-port enabled vs-index 51 } [root@SN234YLNW1V0001:Active:In Sync] tmp tmsh list /ltm pool EC_OPENNET_POOL ltm pool EC_OPENNET_POOL { members { DRA1:diameter { address 10.26.81.30 session monitor-enabled state down } DRA2:diameter { address 10.26.81.38 session monitor-enabled state up } DRA3:diameter { address 10.26.81.46 session monitor-enabled state down } } monitor TCP-3868 }
