not sure where this should go, but will try here.
Is there a document our procedure to mount a usb memory stick on an LTM running 9.3.1.
Purpose would be to move files back and forth to a device that may be off line.
I am not asking about booting from USB CDROM. Looked at askf5 and could not find anything.
Thanks!
jrstewart -
The drive will need to be formatted with FAT or FAT32. Do the following:
1. Plug the drive into the USB slot
2. type:
dmesg | grep "SCSI device"
…and make note of the device identifier (which should be ‘sda’ or something along those lines)
3. type:
mkdir /mnt/usbdrive
4. then:
mount -t vfat /dev/sda /mnt/usbdrive
5. finally:
cd /mnt/usbdrive
…which should put you into the USB drive. When you need to pull the thumbdrive, do:
cd /; umount /dev/sda
makes sense, get an error, wonder what sticks work
hoolio
4
The only reference I could find is from the release notes:
* USB Consortium as a Mass Storage Device certified
* USB version 2.0 or later
* 512 MB minimum capacity, recommended 1 GB capacity
The device capacity and capabilities are described in the following table.
Note: While smaller capacity devices are supported, we recommend using a device with at least 1 GB capacity.
If a key works for the installation, I’d expect it would be mountable after installation.
Aaron
