more than one pool in an iRule
How can I have requests to be evenly distributed across 2 (or more) pools under the same “if” condition in an iRule? For example, If I configure an iRule like:
if { [HTTP::uri] contains “XXXX” } {
pool pool_1
pool pool_2
all the requests are going to pool_2 only. I have 2 pools because they run two different services (i.e., pool_1 serves a port different from the one served by pool_2)
Thanks in advance.
All requests are going to pool 2 because the pool command does not cause the iRule to stop executing code. The second pool command is executed immediately after and the pool is changed from pool 1 to pool 2.
You actually don’t need two pools. A pool can consist of members that are listening on a variety of different ports.
-Brian
