Hello all,
I wondering if possible to apply more than one class in ASM for one virtual IP?
Each class belong to specify URLs.
I want to do this to build different ASM policies from my application.
Thank you.
Hello all,
Thank you.
yes sure,
attention to the order of insertion, the more specific up and the minor specific ( example all traffic ) down.
this way you can create more 'web application, each linked to the path (or other criteria)
bye
mauro
Hi mauro,
Thank you it worked with me.
I did it before without any result the reason was I picked URL with less violation.
Best Regards,
