Hi all,
Is there a way to monitor a port for a telnet response, on say port 7171?
If I run a normal telnet I get the usual blank screen, whereas if it fails I need a monitor to mark it as down.
Thanks in advance,
Jonathan
Hi all,
Thanks in advance,
Jonathan
Did you tried tcp monitoring? Backend service running on port 7171 is what http? web application that need any authentication?
Hi there, No this isn’t a web service - this is a service running over the port that doesn’t give a web response.
I suspect you may be able to create a TCP monitor that Sends a telnet command, and check the response for something that telnet would reply (string matching).
You say that the server doesn’t normally send anything back to the client - do you mean it connects and then waits for the client to send something, and only then returns data ? If so, then you could use a telnet monitor to send a particular string and look for a particular reply.
If you only want to check whether the TCP three-way-handshake was successful, you can use a TCP monitor with no send or receive string specified. This will only test the 3WHS and nothing more.
You could also potentially use a TCP half-open monitor, which sends a SYN, and marks up if it gets a SYN+ACK in reply (if the port is closed, it gets a RST).
