Can we configure F5 content health check for varnish nodes? varnish nodes doent have any content file.
Are there services that are running on the server you could check? You can create a variety of different monitors to check the servers, including tcp or just icmp. An icmp monitor is pretty simple and you can assign it to the node itself to check connectivity.
