Monitor status for 11.2.1
kindly i need from the QKview to figure out which health monitor is available, my system is running 11.2.1, so the /var/lo/ltm is not useful here, thanks in advance!
Have you tried uploading it to iHealth and seeing if you can find what you’re looking for there?
are you looking for monitors which are currently in use or which are available on the bigip ?
for monitors applied at specific pool.
Check this SOL, it seems to be a way to solve your problem.
Piotr
Not sure if i got the question if you are looking for monitor applied by you for monitoring your backend applications .
b pool list | grep monitor ---> this should give you monitor applied at pool level
I hope this you were asking for .
Regards
thanks for your replay, I have pool with 3 health monitors if any one goes down. the whole pool goes down, at 11.2.1, I can see which health monitor made the that pool down, at 11.4.1 and later, i can see it from /var/log/ltm clearly, so I’m asking about a way find which health monitor made the pool down. kindly let me know if you need more clarification.
Okay then Piotr has send link above , it might be useful …
