I’m not sure why you’re getting this error, but it looks like a client-side deserialization error from Apache Axis toolkit. I’ve been running get_template_list method over and over, and there seems to be no problem.
This is what the actual XML payloads look like for both the request and response. Can you check to see if you’re getting something similar to this?
REQUEST
POST /iControl/iControlPortal.cgi HTTP/1.1
User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 1.0.3705.6018)
Content-Type: text/xml; charset=utf-8
SOAPAction: “urn:iControl:LocalLB/Monitor”
Authorization: Basic YWRtaW46YWRtaW4=
Content-Length: 496
Expect: 100-continue
Host: localhost:8080
xmlns:soap=“http://schemas.xmlsoap.org/soap/envelope/” xmlns:soapenc=“http://schemas.xmlsoap.org/soap/encoding/”
xmlns:tns=“urn:iControl”
xmlns:types=“urn:iControl/encodedTypes”
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:xsd=“http://www.w3.org/2001/XMLSchema”>
RESPONSE
HTTP/1.1 100 Continue
HTTP/1.0 200 OK
Date: Tue, 13 Sep 2005 20:40:45 GMT
Server: Apache
Set-Cookie: BIGIPAuthCookie=368F251F0C5DBA5780F668F2C9FBB18A6FBA8ED4; path=/; Secure;
SOAPServer: EasySoap++/0.6
Connection: close
Content-Type: text/xml; charset=“UTF-8”
xmlns:E=“http://schemas.xmlsoap.org/soap/envelope/”
xmlns:A=“http://schemas.xmlsoap.org/soap/encoding/”
xmlns:s=“http://www.w3.org/2001/XMLSchema-instance”
xmlns:y=“http://www.w3.org/2001/XMLSchema”
xmlns:iControl=“urn:iControl”
E:encodingStyle=“http://schemas.xmlsoap.org/soap/encoding/”>
xmlns:m=“urn:iControl:LocalLB/Monitor”>
s:type=“A:Array”
A:arrayType=“iControl:LocalLB.Monitor.MonitorTemplate[28]”>
s:type=“iControl:LocalLB.Monitor.MonitorTemplate”>
s:type=“y:string”>none
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_NONE
s:type=“y:string”>icmp
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_ICMP
s:type=“y:string”>gateway_icmp
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_GATEWAY_ICMP
s:type=“y:string”>tcp_echo
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_TCP_ECHO
s:type=“y:string”>tcp_half_open
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_TCP_HALF_OPEN
s:type=“y:string”>http
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_HTTP
s:type=“y:string”>external
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_EXTERNAL
s:type=“y:string”>udp
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_UDP
s:type=“y:string”>ftp
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_FTP
s:type=“y:string”>nntp
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_NNTP
s:type=“y:string”>pop3
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_POP3
s:type=“y:string”>smtp
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_SMTP
s:type=“y:string”>imap
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_IMAP
s:type=“y:string”>radius
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_RADIUS
s:type=“y:string”>ldap
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_LDAP
s:type=“y:string”>mssql
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_MSSQL
s:type=“y:string”>oracle
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_ORACLE
s:type=“y:string”>scripted
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_SCRIPTED
s:type=“y:string”>wap
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_WAP
s:type=“y:string”>wmi
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_WMI
s:type=“y:string”>real_server
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_REAL_SERVER
s:type=“y:string”>snmp_dca
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_SNMP_DCA
s:type=“y:string”>snmp_dca_base
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_SNMP_DCA_BASE
s:type=“y:string”>https
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_HTTPS
s:type=“y:string”>sip
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_SIP
s:type=“y:string”>soap
s:type=“iControl:LocalLB.Monitor.TemplateType”>TTYPE_SOAP
s:type=“y:string”>https_443
