Monitor log
Cannot parse the http request. Http error response [400 Bad Request] will be returned. Request is [GET /index.html
com.sap.engine.services.httpserver.exceptions.HttpIllegalArgumentException: Illegal argument(s) [., 21] of method [indexOf] in class MessageBytes.
at com.sap.engine.services.httpserver.lib.util.MessageBytes.indexOf(MessageBytes.java:563)
at com.sap.engine.services.httpserver.lib.impl.RequestLineImpl.init(RequestLineImpl.java:282)
at com.sap.engine.services.httpserver.lib.impl.RequestLineImpl.parseRequestLine(RequestLineImpl.java:213)
Hi Jimmy,
Which LTM version are you running? What is the monitor send string configured as?
Aaron
Jimmy: A good first thing to check is that you’ve got a HOST header included in the request, for example:
GET / HTTP/1.1\r\nHost: host.domain.com\r\nConnection: Close\r\n\r\n
-Matt
