Monitor Help with SSL certs
Hi
I don’t know if anyone has run across this problem or not but I have an application that I’m trying to monitor that is throwing a client certificate accept screen back to the big-ip and my https content monitor is failing because it doesn’t know how to get wround this problem.
Is there anyway to get around this? or fix it?
Many thanks.
Hello,
This isn’t rule related so the question should be directed to support. However, in the HTTPS monitor configuration options, you can specify a client SSL certificate that the BIG-IP will present to the nodes.
Here is a note from the online help:
Client Certificate
Specifies a fully-qualified path for a client certificate that the monitor sends to the target SSL server.
If you want more detail, I imagine the LTM config guide has it.
Thanks,
Aaron
Many thanks!
