Hello: look at the image to configure Sflow , and look at the detail of solorwinds; Solorwinds detail for node f5 are not avaliable because netflow and CBQos data are not avaliable.
Hi Yuanqiang~ I’m really not sure what’s happening with your situation but I did find a couple documents that cover Sflow:
Manual Chapter: Monitoring BIG-IP System Traffic with sFlow - 404 Page not found | BIG-IP Documentation
and
SOL15193: sFlow traffic will use only the self IP address of the BIG-IP system as the egress interface - 404 Page not found | BIG-IP Documentation
and
Manual Chapter: Configuring Performance Monitoring - 404 Page not found | BIG-IP Documentation
Also if you go to and search ‘sflow’ you’l get some other resources.
hope that helps.
ps
