Monitor availability of Virtual servers using SNMP
Hello,
I am trying to monitor our BigIP ( BIG-IP 10.2.2 Build 930.0 Hotfix HF3 ) through SNMP.
One of the report that I have develop is to monitor the availability of the Virtual Servers.
I am polling the following SNMP OID (ltmVirtualServAvailabilityState).
It only return the status on the common partition. Our F5 are configured with 2 partition.
I quickly searched on DevCentral and find this link
This issue should have been fixed in release (9.4.2).
Can someone advise how to poll the status of the Virtualserver on the non common Partition?
Abdel
can you try this?
[root@ve1023:Active] config  b version|grep -iA 1 version
BIG-IP Version 10.2.3 112.0
Final Edition
[root@ve1023:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.79:80
   partition par1
[root@ve1023:Active] config  b pool foo list
pool foo {
   monitor all http
   partition par1
   members 200.200.200.101:80 {}
[root@ve1023:Active] config  snmpwalk -v 2c -c public localhost F5-BIGIP-LOCAL-MIB::ltmVsStatusAvailState
F5-BIGIP-LOCAL-MIB::ltmVsStatusAvailState."bar" = INTEGER: green(1)
[root@ve1023:Active] config  snmptranslate -On F5-BIGIP-LOCAL-MIB::ltmVsStatusAvailState
.1.3.6.1.4.1.3375.2.2.10.13.2.1.2
