Monitor always show nodes up even if down ...
Hi all, I’m wondering what’s wrong in the external monitor I have created. Target is to monitor NTP server status.
I get the correct status (UP, DOWN) when I run the batch via SSH on the F5 VM
It DOESN’T run via the MONITOR … status is always up and I get the message “exceeded monitor interval” in the LTM
I spent hours on it without finding the error … Sure I miss something … help ! … please
thanks
Here is the code :
!/bin/bash
 target is to monitor the NTP appliances and to log their status
 Log debug to local0.debug (/var/log/ltm)?
 Check if a variable named DEBUG exists from the monitor definition
if ! [ -n "$DEBUG" ]
then
    If the monitor config didn't specify debug, enable/disable it here
   DEBUG=1
fi
 Remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
IP=`echo $1 | sed 's/::ffff://'`
 Save the port for use in the shell command
PORT=$2
 Check if there is a prior instance of the monitor running
pidfile="/var/run/`basename $0`.$IP.$PORT.pid"
if [ -f $pidfile ]
then
   kill -9 `cat $pidfile` > /dev/null 2>&1
   echo "NTP server $IP `basename $0`: exceeded monitor interval, needed to kill ${IP}:${PORT} with PID `cat $pidfile`" | logger -p local0.error
fi
 Add the current PID to the pidfile
echo "$$" > $pidfile
 NTP status
command="ntpdate -q $IP"
eval "$command  2>&1 > /dev/null"
 if the NTP server is reachable
if [ $? -eq 0 ]
then
    Extract the offset (before the floating point)
   result=$(eval $command)
   arr=($result)
   offset=${arr[5]}
   declare -i offset=${offset%%.*,}
    if offset < 1 sec then node is UP
   if [ $offset -gt -1 ] && [ $offset -le 1 ]
   then
      rm -f $pidfile
      echo "UP"
   else
      rm -f $pidfile
      if [ $DEBUG -eq 1 ]; then echo "NTP server $IP out of sync offset=$offset" | logger -p local0.debug; fi
   fi
else
   rm -f $pidfile
   if [ $DEBUG -eq 1 ]; then echo "NTP server $IP not reachable" | logger -p local0.debug; fi
fi
If something goes to stdout the system marks it as up. Looks like your debug is doing that.
In relation to the monitor interval, make sure it takes less than the internal to run the script.
