Modifying variable 'configsync.peerconfigtimeraw'.
Hello
I have these messages in /var/log/ltm
Nov 11 07:03:01 bigIP bigdbd[1911]: 01080038:5: Modifying variable ‘configsync.peerconfigtimeraw’.
Nov 11 07:03:03 bigIP bigdbd[1911]: 01080038:5: Modifying variable ‘configsync.peerconfigtimeraw’.
Nov 11 07:03:31 bigIP bigdbd[1911]: 01080038:5: Modifying variable ‘configsync.peerconfigtimeraw’.
Nov 11 07:03:33 bigIP bigdbd[1911]: 01080038:5: Modifying variable ‘configsync.peerconfigtimeraw’.
I run b config sync all; but it failed so my question is if is this related to failed sync command and how to solve this issue
Thanks in advance
What’s the config sync error you’re seeing? You can troubleshoot the failure following the steps in SOL7024:
SOL7024: Overview of the ConfigSync process
I think the message you’ve posted indicates that the peer’s configuration has changed. Is the peer unit’s config changing that often? Which LTM version are you running?
Aaron
