Hi all, I’m attempting to log certain requests to an external datagroup in order to provide the logged data to management. The situation is we are testing out a new design of our site. I’ve got working irules to provide certain users a cookie and then changing their pool based on the cookies value. I would like to then log to a file those users who have opted out. The goal is to do something like this tmsh command but inside the irule:
tmsh modify ltm data-group uid_optout_list records add { $fool_UID }
Where the $fool_UID is found by examining the incoming cookie and parsing out their UID. This happens earlier in the code and is working as expected, e.g. log local0. “NAT - UID $fool_UID” performs as expected.
Relevant subset of pool mapping code
the cookie will either be "true%3D[an epoch time]" or "false%3D[an epoch time], so we split out true or false to test
if {([lindex [split [HTTP::cookie value "NewArticleOptIn"] "%3D"] 0] equals "true") and not ($legacy_query_var equals "true")} {
log local0. "NAT - hit article, optin true - $path"
if { [class match $path starts_with tmf_poolmap_newsiteall]} {
log local0. "NAT - class file hit - in poolmap"
set tmfpool $tmfpool-django
} elseif {([lindex [split [HTTP::cookie value "NewArticleOptIn"] "%3D"] 0] equals "false") and not ($legacy_query_var equals "true")} {
checking for people who have opted out
get the Fool UID from Fool cookie. parse the UID out by using a temporary variable to get everything after the = and then splitting on the & to remove the end
set fool_cookie [HTTP::cookie value "Fool"]
set fool_UID1 [lindex [split $fool_cookie "="] 1]
set fool_UID [lindex [split $fool_UID1 "&"] 0]
log local0. "NAT - attempting to log false"
unset fool_UID1 fool_UID fool_cookie
Code setting the cookie for certain users based on point of entry into the site and if they already have it or not.
if { [class match $path starts_with tmf_poolmap_newsite] } {
if the cookie doesn't exist, set it to true on response. we don't want to mess with an existing cookie
if {not [HTTP::cookie exists "NewArticleOptIn"]} {
unset fool_UID1
if {[class match $fool_UID equals tmf_uid_list]} {
set new_user "true"
when HTTP_RESPONSE {
if new_user isn't null, we need to send them the cookie
if {[info exists new_user]} {
set now [clock seconds]
set cookie [format "%s=%s; domain=%s; expires=%s; path=/;" "NewArticleOptIn" "true%3D$now" ".fool.com" "[expr $now + 31536000]"]
HTTP::header insert "Set-Cookie" $cookie
remove the variables if they exist
unset new_user
unset fool_UID
unset fool_cookie
So where I currently am logging to /var/ltm/log, I’d like to drop it into an external datagroup instead so that I end up with one list of unique keys. I’ve spent a few hours looking for this and can’t seem to arrive at a solution, so any guidance would be appreciated. We’re currently on 10.2.4 and will be updating to 11.5.1 soon, so my suspicions would be that this needs to use tmsh instead of bigpipe, but if bigpipe gets me to a working solution today, that’s fine with me. There is also likely a more elegant way to parse their UID out from the Fool cookie, but that way was quick and working. If you want to advise me on that, the cookie’s structure is
Uid=&someotherdata
Thanks for your time!
P.S. in case you’re wondering, I’m not calling my opt-out users fools! I work at The Motley Fool, so it’s a term we use positively.
