Here are a whole bunch that you may use (with extreme caution of coarse because lazy_sysadmin & be especially cautious on systems that use non-http virtual servers like ldap):
Lists the names of the virtual servers with the basic tcp profile assigned:
tmsh list ltm virtual one-line | grep "profiles.*\ tcp\ " | awk ‘{ print $3 }’
Changes the individual virtual server’s profile manually (edit VIRTUAL_SERVER_NAME to whichever one you want to edit):
tmsh mod ltm virtual $VIRTUAL_SERVER_NAME profiles add { tcp-wan-optimized { context all } } profiles delete { tcp }
This is ugly but performs the previous two steps on all virtual servers that need the change made:
tmsh list ltm virtual one-line | grep "profiles.*\ tcp\ " | awk ‘{ print $3 }’ | xargs -I vs_name tmsh mod ltm virtual vs_name profiles add { tcp-wan-optimized { context all } } profiles delete { tcp }
Lists the virtual servers with only simple http compression applied:
tmsh list ltm virtual one-line | grep "profiles.*\ httpcompression\ " | awk ‘{ print $3 }’
manually change individual virtual server (edit variable):
tmsh mod ltm virtual $VIRTUAL_SERVER_NAME profiles add { wan-optimized-compression { context all } } profiles delete { httpcompression }
Again, super ugly but does the job. Move all to wan-optimized-compression:
tmsh list ltm virtual one-line | grep "profiles.*\ httpcompression\ " | awk ‘{ print $3 }’ | xargs -I vs_name tmsh mod ltm virtual vs_name profiles add { wan-optimized-compression { context all } } profiles delete { httpcompression }
Wait a sec, which ones do not have the wan-optimized-compression profile enabled?
tmsh list ltm virtual one-line | grep -v " wan-optimized-compression\ "
Apply this to all of them:
tmsh list ltm virtual one-line | grep -v " wan-optimized-compression\ " | grep virtual | awk ‘{ print $3 }’ | xargs -I vs_name tmsh mod ltm virtual vs_name profiles add { wan-optimized-compression { context all } }
