Modify uri path using local traffic policy instead of IRule
Hi all
Im using my F5 BIGIP (v13) as reverse proxy to publish some websites by using local traffic policies.
But i need to perform a URL rewriting. To be specific, i need to strip a string from the URI path.
When applied as IRule it works correctly as I want:
when HTTP_REQUEST { if { [string tolower [HTTP::uri] ] starts_with “/path1” } { HTTP::uri [string map {“/path1/” “/”} [HTTP::uri]] node 10.10.10.20 8000 } }
But when using local traffic policy it does not work as expected:
Replace - HTTP Uri - PATH … with value… tcl:HTTP::uri [string map {“/path1/” “/”} [HTTP::uri]]
Am i doing something wrong? What would be the correct way?
Thanks all!
Hi
you don’t have to put the HTTP::uri in tcl command:
Replace - HTTP Uri - full ... with value... tcl:[string map {"/path1/" "/"} [HTTP::uri]]
Hola Javier, How are you publishing the URLs? is it using a single VS for all the URLs or a different IP Address on each URL? as we want to do something similar
Hi!
Yes, i have published multiple sites in a single VS. Check this I post i have just published in which it is explained:
F5 BIGIP – Name based reverse proxy (LTM policies)
Hope it helps!
Hola Javier, I follow your guide and that was very handy, a quick query about it:
  • On the VS, we don’t need to associate it a Default Pool, do we? as my thoughts are that, once a connection hits the VS, the policy associated to that VS will select to which pool or node that to be sent internally [as Reverse Proxy based on URI]
Let me know please
Hi Atif! Correct. The “default pool” is left set to “None”. The logic to select node/pool/VS will be applied by using a policy that is assigned as shown in the post.
Javier, if we want to Load balance the request coming to the reverse proxy, is that what I need to do: on the Policy rule applied to the VS, when the traffic is matched, send it to a pool [where the members of the pool will be nodes with different IP addresses to be load balanced on each request].
Let me know please
