modify tcp_half_open
I have several pools that monitor tcp_half_open and I would like to modify them so that they monitor tcp. So my goal is to remove the tcp_half_open on each pool and have it monitor tcp. Below is an example of that it looks like now: ltm pool ARCH_PE_DataJunction_arch_pe_DJport7110 { members { 20.20.142.68:7110 { address 20.20.142.68 session monitor-enabled state down } 20.20.142.69:7110 { address 20.20.142.69 session monitor-enabled state down } 20.20.142.70:7110 { address 20.20.142.70 session monitor-enabled state down } 20.20.142.71:7110 { address 20.20.142.71 session monitor-enabled state down } 20.20.142.72:7110 { address 20.20.142.72 session monitor-enabled state down } } monitor tcp_half_open }
I was wondering if anyone could supply me with what the syntax would look like to modify this without any issues.
It should be as simple as executing the following TMSH command:
tmsh modify /ltm pool  monitor tcp
For example, to modify the pool you cited in your question:
`tmsh modify /ltm pool ARCH_PE_DataJunction_arch_pe_DJport7110 monitor tcp
As for whether changing the monitor will produce issues or not, there are always things to consider. The tcp_half-open monitor does a SYN/SYN-ACK followed by a RST. The tcp monitor does a full 3-way handshake (SYN/SYN-ACK/ACK) and then sends a FIN. This may have an impact in your environment as clearly the volume of traffic per monitor test is different.
