Modify priority of pool members using iRules
Hi all
I have an application which has the specific requirements:
  • Two nodes in the pool.
  • Send all requests to only one node during normal operation (hence using priority group activation).
  • If the favoured node fails, then send all requests to the second node in the pool.
I understand there are implications here around availability, capacity etc, but the application team is aware of this and specifically want this setup. If the favoured node comes back online in the above example, the application team want the F5 to continue sending all requests to the second node to avoid outages.
My issue with the above is this:
  • If the favoured node comes back online, it will be ignored and never used.
  • Once this happens, if the second node in the pool fails (after it has already been selected as the sole node to use), traffic will not automatically be redirected back to the favoured node and no node will be selected.
I was thinking there may be some way to achieve the automatic redirection back the favoured node using “Action on service up”, but sadly no event is available. Alternatively, it might be possible by programatically modifying the pool member priority values, but I’m not too sure of how this might be implemented.
Is there any way I can achieve the above functionality automatically on the F5?
is single node persistence usable?
Single Node Persistence
That’s a really interesting link and something I was unaware of, so thanks for posting! After reading through the entirety of the article, it seems this may not be suitable for situations requiring prioritisation of nodes within the pool though? This is the requirement we are facing, so we do need some way to cater for this. Are there any options with this in mind?
is LB::status useful (i.e. manually select pool member for the first request)?
e.g.
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.24.10:80
    ip-protocol tcp
    mask 255.255.255.255
    pool foo
    profiles {
        http { }
        tcp { }
    rules {
        qux
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 41
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:80 {
            address 200.200.200.101
            session monitor-enabled
            state up
        200.200.200.111:80 {
            address 200.200.200.111
            state up
    monitor gateway_icmp
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
    when CLIENT_ACCEPTED {
  if { [persist lookup uie 1] ne "" } {
    persist uie 1
    if { [LB::status pool foo member 200.200.200.111 80] eq "up" } {
when SERVER_CONNECTED {
  persist add uie 1
 persistence
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show ltm persistence persist-records all-properties
Sys::Persistent Connections
universal - 172.28.24.10:80 - 200.200.200.111:80
  TMM           0
  Mode          universal
  Value         1
  Age (sec.)    6
  Virtual Name  /Common/bar
  Virtual Addr  172.28.24.10:80
  Node Addr     200.200.200.111:80
  Pool Name     /Common/foo
  Client Addr   200.200.200.111
  Local entry
  TMM           1
  Mode          universal
  Value         1
  Age (sec.)    6
  Owner entry
Total records returned: 2
by the way, if you want to change pool member priority value, i think alertd or icall may be applicable.
Acton on Log - using the alertd deamon
iCall - All New Event-Based Automation System by Jason Rahm
