I would think this would be a simple fix? would like to disable a VS “test” with tmsh
tmsh modify ltm virtual test disabled
when this is performed this command shows it is disabled: ltm virtual test { destination 1.1.1.1:http disabled ip-protocol tcp mask 255.255.255.255 pool QASSM1_Pool profiles { tcp { } } } however this command shows state enabled: tmsh show ltm virtual test
Ltm::Virtual Server: test
Status Availability : available State : enabled Reason : The virtual server is available CMP : enabled CMP Mode : all-cpus
if i go into the GUI and refresh the VS list it will then go disabled “black” likewise the tmsh show virtual test will then show state disabled. Same is true when enabled when disabled.
I’ve tried the following: tmsh modify /ltm virtual test disabled save sys config partitions all tmsh load sys config
even this will then enable the test VS so not sure what I am missing. Appreciate any ideas.
it seems okay here. i am running 11.5.1.
e.g.
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.24.10:80
disabled
ip-protocol tcp
pool foo
profiles {
http { }
tcp { }
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 46
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show ltm virtual bar
Ltm::Virtual Server: bar
Status
Availability : unknown
State : disabled
Reason : The children pool member(s) either don't have service checking enabled, or service check results are not available yet
CMP : enabled
CMP Mode : all-cpus
Destination : 172.28.24.10:80
Traffic ClientSide Ephemeral General
Bits In 10.4G 0 -
Bits Out 195.8M 0 -
Packets In 884.9K 0 -
Packets Out 470.4K 0 -
Current Connections 0 0 -
Maximum Connections 2 0 -
Total Connections 43 0 -
Min Conn Duration/msec - - 5
Max Conn Duration/msec - - 21.3K
Mean Conn Duration/msec - - 2.9K
Total Requests - - 12
SYN Cookies
Status not-activated
Hardware SYN Cookie Instances 0
Software SYN Cookie Instances 0
Current SYN Cache 0
SYN Cache Overflow 0
Total Software 0
Total Software Accepted 0
Total Software Rejected 84
Total Hardware 0
Total Hardware Accepted 0
CPU Usage Ratio (%)
Last 5 Seconds 0
Last 1 Minute 0
Last 5 Minutes 0
e.g.
ltm virtual bar {
disabled
ip-protocol tcp
pool foo
profiles {
http { }
tcp { }
source 0.0.0.0/0
type automap
vs-index 46
Status
State : disabled
CMP : enabled
CMP Mode : all-cpus
Bits In 10.4G 0 -
Bits Out 195.8M 0 -
SYN Cookies
Current SYN Cache 0
Total Software 0
Total Hardware 0
CPU Usage Ratio (%)
Last 5 Seconds 0
Last 1 Minute 0
Last 5 Minutes 0
perhaps it is because running older 10.2.x code? thanks for your assistance. Looks like yet another reason to convince client to upgrade.
