Modify iApp Resource Names?
Is there an easy way to modify the VS’ and POOL names that iApp templates create? I am picky about my naming convention, and in the past I have modified bigip.conf manually.. but, it would be nice if there was an easier way.
Thanks,
Josh
From my understanding I do not believe you can do this any easier, manually through the cli is still the only option. Otherwise I think you create your own template with your own naming converntion.
