Modify HTTP Payload in Response Question
Hello all
We have a requirement to modify the <HEAD> HTML tag in responses for a specific URL. I’ve been looking around trying to piece bits together but not having too much luck in the lab.
My understanding is to use the HTTP::collect to collect response data then access that data via the HTTP::payload command. I found an example online which I have attempt to butcher with no luck, as below. Hoping for some guidance.
if { [HTTP::uri] starts_with "/home"}{
continue }
when HTTP_RESPONSE {
HTTP::collect [expr 1024*1024]
when HTTP_RESPONSE_DATA {
set find "<HEAD>"
set replace "<HEAD> SOME_OTHER_DATA"
if {[ regsub -all $find [HTTP::payload] $replace new_response] > 0} {
    HTTP::payload replace 0 [HTTP::payload length] $new_response
Thank you.
You can use my example with stream profile.
https://devcentral.f5.com/s/question/0D51T00006sSMmYSAW/insert-javascript-only-if-memberof-equal-some-value?page=4
or modify your irule with the following code:
set find "<HEAD>"
	regsub -all $find [HTTP::payload] $replace newdata
	log "Replacing payload with new data."
	HTTP::payload replace 0 [HTTP::payload length] $newdata
	HTTP::release
regards
