Regarding the latest vulnerabilities, I’m looking for your usual valued advice, what is the best practices to mitigate, I have VE running in version 14.1.2.
Thanks in advance.
Thanks in advance.
Hello @mahjoub ,
You can check this KB :
https://support.f5.com/csp/article/K97843387
it’s about overview November 2022 CVEs.
> Navigate the hyperlinkes below " High CVEs"
and check how to mitigate each vulnerability.
> If you have an access for F5 iHealth tool , upload you Qkview and follow the below KB to check if there are vulnerabilities still hasn’t been mitigated.
KB : https://support.f5.com/csp/article/K27404821
Regards
Hey @Mohamed_Ahmed_Kansoh - I’m marking your reply as the Accepted Solution.
@mahjoub , if it doesn’t work for you, please let us know. ![]()
